Moparmatt72
Location Riverside, Ca
I have my 72 satellite that I won't be able to get to since taking on a 67 dart. It has a 440 bored .060 with good meat left on the cylinders, head and mains studded, 11.5:1 ratio hyper pistons, CAT h beam rods, factory steel crank all balanced, Isky 292 cam, dual roller timing chain,440source stealth heads with CAT 1.7 rockers, home gaskets matched, M1 intake with a 1050 Dom. Hooker supercomp headers, flanges removed and install v band, have the other side and clamp. 440 source oil pan and water pump, housing is aftermarket aluminum, Griffin dual pass rad. Only have one 12" fan was going to install another, b&m oil cooler and trans cooler. Dual Oil filter relocation kit. Trans is a 727 warmed up can't remember what's all in it but had the red bands, J&W reverse Manuel VB, Hughes 3500 stall, no drive shaft, Dana rear end taken out of a truck, new end tubes, 4:56:1 gears and a locker, strange drag rear disc(not plumbed). Have fiberglass door for it from US body, no front fenders,hood or deck lid, have satillite grill insert, decent shape, rear tail light lens okay condition, has painless wiring 8 switch panel just holding on to the windshield trim till I was going to have a cage put it. Summit poly seats with covers, S&W aluminum dash, all gauges are new except the tach, MSD 7al box, HVAC coil, and Mopar race wires. Aeromotive A2000 fuel pump and reg. , 20 gal fuel cell hasnt been mounted, is a square cut in the floor from the previous plastic cell that was in there.Haven't ran the engine in a long time. Summit brand wheel, have 15x4 front and 15x10 rears, will bring down the fronts when i come back to cali, moved to Idaho. Hoping to get $3000. Have stock header panel and front valance, new carpet kit and I believe a new seal kit for the car, will have to double check that. Car is at my brothers house but now he's moving to Utah for a job, will be down July 24 evening but all day the 25. If interested let me know. Have had this car since I was 16 my first Mopar
Can email a video of the first time we started it, can't seem to be able to upload, pm for video
