Radiator / Grill Support Bracket adjustment?
bigmanjbmopar
Newb with a view
10:13 PM
zION
In the process of replacing the the grill filler panel and grill parts, got bumper off (pita bumper bolts) and stood back and noticed the top grill support bracket was lower on the drivers side than the passengers side. I see two bolts at the bottom of the center bracket - loosen those and can get some adjustment but makes it worse.
Does anyone have a picture of their front end without the bumper? Also the center bracket for the grill support looks bent or offset to the right? Is this normal? What am I looking at?
overall pic
Center bracket
Google pic of whole assembly
You should be able to adjust the latch support plate right or left at the top where it bolts to the upper cross plate. See if that helps.
I can check my 73 at the yard in the morning.
