Ralley dash bulb placement
Gregg DeGeorge
11:04 AM
Naugatuck Ct 06770
Hello ,I did print out wiring diagram off on my mopar ;trying to wire cluster before I drop it in the dash which is out of car switch’s were easy to figure out ;but the different bulbs with different colored wires thinking light green is for signal and the brown ;red high beam indicator one bulb has two wires black and green with white tracer ;not sure where this one goes. Thanks
Light green: left turn signal
Red: hi beam
Tan: right turn signal
As for the two wire, I'm just guessing, since I can't remember: parking brake? You should be able to kind of tell on most, since they don't give you a whole lot of wire to play with!
Red: hi beam
Thanks that helps won’t know until that first start up ,car was all apart when I bought it thanks Again
