Rear Drum Brake questions
MoparMur
8:39 PM
Lethbridge, Alberta, Canada
First of all a Happy Father's Day to all! My question deals with rear drum brakes. I'm planning on switching a '66-'70 B-Body 8 3/4 complete unit (housing, axles, everything) into our '64 Polara convertible. Seeing that I'll be starting fresh with all parts I may as well put on the largest factory drum brake setup that Ma MoPar offered. I'm thinking that there may be some C-Body brake assemblies out there, or even Pick-Up brakes, that may fit on to the factory B-Body rear end to gain some brake size. Any suggestions?
If you are running four wheel drums then 11 x 3 on the front and 11 x 2.5 on the rear would be the best. That is what hemi cars ran. They did make a 11 x 3 setup for the rear, but would probably be hard to find , and would be overkill.
They also made 11x2'' on some C bodies in the rear. Mid 70's. Had a 74 Monaco that had them.They can be used on the 8 3/4'' with the proper backing plates.If you are junk yard shopping.
You are not going to using the vehicle as a taxi cab in Manhattan....
The standard Big Block 11" x 3" Fronts. & 11" x 2 1/2"
Rears will be more than adequate...
As suggested above, if you want to get extra funky -- you can try and locate 11" x 3" Rear backing plates -- but they were only used on police cars, ambulances, heavy duty 300s and Imperials -- so they are not next to the string beans in the supermarket....
And, I have everything brand new for you ---
N.O.S. ++ Asbestos ++ brake shoes , wheel cylinders, brake hardware -- combo kits, adjuster kits, and the e-bar springs, and the brake drums N.O.S. U.S.A. made.
Basically, everything from the backing plates outward.
Always best to simply call me -- Craig -+
.....Long Island, New York...
You can never say never,or always, when it comes to muscle era mopars, but 67 GTXs with drum brakes as well as all other drum brake GTXs and R/Ts etc. Came with 11 x 2.5 rear brakes. If one of these cars left the assembly line with 11 x 3 rear brakes, it would be an unusual situation.
Bought a Dana 60 with 11x3's out of a 67 GTX a kid was parting out. He shouldn't done that, it was a solid car. It was a shell when I bought the rear.
Bought a '67 GTX in early '80's, original 440 auto, 8.75 car. 11" x 3" all the way around. Have all of that braking system on my '67 Belvedere currently (wrecked GTX). Thought it was common knowledge that all '67 GTX's came that way.
I have a pile of rear drum brake parts and am trying to fit it all together. Most of it is 10" stuff, just fine for front disc cars.
