Rear end in Tampa Fl
Ellis
9:29 PM
Tampa Fl
Feedback: +0 / =0 / -0
Looking for a dana 60 or 8 3/4 rear for a 74 charger with or without springs.
Ellis---Im across the state in Ft Pierce & I have several 8-3/4 rears that should fit your B-body--Springs as well if you need them--let me know
I got an E body 8 3/4, which is only about an inch different.
Has backing plates. Also have an open 2.76 chunk.
There are at least 7 complete rear ends, all 8-3/4 sitting here with & without center chunks & if anyone needs a chunk,I have 19 units on the shelf--2 are 3:55s--1 is a 742 unit--1 is a 489 unit-- all spin freely--look good--$700.00 plus the ride for posi's--$350 for open units--They weigh about 75 pounds--there is a 741 chunk with posi 3:91 gears;--1- 741 posi unit with 3:23 gears- and 1-741 posi unit with 4:10 gears-and all the others are open--all the rest have gear ratios from 2:76--2:94--3:23--no 3:55 open--& 3:91--also 2 -489 empty houseings for $75.00--and yes they are called sure grip but posi sounds cool--I also have a few sets of 11 inch backing plates & a couple 10 inch backing plate sets if anyones interested--$100.00 for the plates as most have everything on them-- its all for sale
cant wait until tax time, you have exactly what i need.
