Rear exhaust manifold deep hollow nut on B-Block
Resto_1
3:13 AM
USA
Good Evening All,
Can someone post a picture of the deep hollownut that is used on the B-Block exhaust manifold? Have used penetrant for a couple weeks while I've been away from the project. No luck. Used my induction heater and smacked the nut with a hammer to no avail, defintely don't want to break the stud. Would like to see what I'm working with(against). Thanks
Good Evening All,
Can someone post a picture of the deep hollownut that is used on the B-Block exhaust manifold? Have used penetrant for a couple weeks while I've been away from the project. No luck. Used my induction heater and smacked the nut with a hammer to no avail, defintely don't want to break the stud. Would like to see what I'm working with(against). ThanksView attachment 1985155
Here's what the nuts look like on ebay:
Great responses, Thanks. My concern is breaking the stud of in the head.
Heat it cherry red a couple times with a torch and then quench it with a hose with cold water. You could try that several times. If it breaks you might have to pull the head. No big deal.
It's a 3/8" stud, it won't break that easily. If you are heating it you will need to get it hot on the end for some time for it to travel into where the threads are.
The latest one I worked on some fool use short Allen head bolts so I needed a long Allen socket to reach down in 3" and they were very tight.
