PurpleBeeper
I've had a really bad oil leak (1 qt./30 miles) on an engine that I revived (not run) in nearly 20 yrs. It looked like a rear main seal, so I changed it. The old seal looked pretty good though, but I changed it anyway. The engine still leaked oil like a sieve.
I pulled the trans/clutch & had my buddy prime the oil pump.... rear main seal leaking.
I read the FBBO sticky on rear main seals & bought one of those "gizmos" (fancy rear main seal cap) that is supposed to help + the top of the line gaskets. They're on the way. I plan to install it exactly as shown with calipers & 2 sets of feeler gages, etc.
I also noticed a note that said "for bad rear main leaks, sometimes milling .010" off the rear main seal cap helps by squeezing the rear main seal tighter". This got me thinking. I did have this block align honed MANY years ago & I'm not sure if they milled the rear main seal "cap" when they milled the main caps.
What do you guys think about doing this? Should I just see if this new cap works first, or go ahead an mill it .010" now? What have all of you experienced with rear main seal leaks that might help me? I did end up slightly oiling the clutch disk ($200) & I don't want to buy a 3rd one. I don't remember this engine leaking oil like this 20 yrs. ago when it was my daily driver.
THANKS FOR THE HELP
THANKS FOR THE HELP
