Rebuilding a 8.75 rear? Brake upgrade?
Wilstruck
New Member
10:02 PM
New Jersey
Could i upgrade rear from 10inch brakes to 11 ? Would i have to change anything other then drums, backing plates, and hardware?
Thanks
Will
Should just bolt on. I bagged an 11" setup off of a later Chrysler and it bolted right on.
If you're going with 11's in the rear hopefully you have 11's in the front or discs.
FYI: My 68 RR is a factory disc brake car and it came with 10" rear drums, probably because 11's would have had a tendency to lock up. My 69 RR is a drum brake car and it's 11" all around.
