FOR SALE Rebuilt B-body A-833 Swap "Kit" (Transmission, shifter, pedals, misc)
jwrich
11:26 PM
Marshalltown, Iowa
Feedback: +0 / =0 / -0
Fully REBUILT 1968 Mopar B-body A833 4-speed manual transmission, REBUILT pedal assembly, REBUILT hurst shifter, shift rod, new linkage rods, floor pan hump, shift fork and equalizer bars. All sells together. Transmission shifts smoothly and shifter operates nicely. 0 miles on this. 23 spline input shaft. Freshly rebuilt! Almost everything you will need for your swap project! (Will fit other years b-body as well)
Transmission was rebuilt with all new roller bearings, needle bearings, thrust washers, reverse switch, gaskets, etc. Blasted & painted in cast iron grey.
Pedal assembly was cleaned and refinished, then reassembled with all new bushing and roller bearings and new foot pads
Hurst shifter was fully disassembled, cleaned, lubed, and reassembled to spec.
Shift rods and retaining clips are all new.
I believe the center hump is from a roadrunner.
FLYWHEEL AND BELL HOUSING SHOWN IN PICTURE ARE NOT INCLUDE (FLYWHEEL WAS FOUND TO BE CRACKED AND BELL IS FOR A SBM)
Located in Marshalltown, Iowa (Prefer not to ship)
$2500 for everything
