There is so much information regarding conversion to electronic ignition....All state that you should upgrade the Alternator and to an electronic voltage regulator. What is the reason for doing this?
Early Charging System modified for use with a 70 style VR
There are a number of reasons one might want to upgrade a per-1970 system to a transistorized voltage regulator. The list of reason include
Chrysler recommends you switch to a transistorized VR if you upgrade to an electronic ignition from a points style ignition.
If you have to buy a new voltage regulator, the difference in cost is only about $5-10 more for the transistorized unit. Not to mention, the quality of replacement early style VR's is spotty.
Electronic ignition pretty much mandates a constant, reliable source of voltage for it to operate the best. Ma Mopar always recommended a conversion to electronic regulators with their ignition conversion kits and made a special VR that used the old points type regulators' wiring. I wonder if they still make that unit, was pretty slick?
Have not been able to find one at Mopar....just the updated 2 field units.....there are some on e-bay....found one at OReillys last week Master Pro 2-VR9
