Brandy
Jack Stand Racer #6..and proud of it!
- 2:48 AM
- Oct 16, 2014
- Salisbury, Vermont
Have some questions about welding in place the new perches for the leaf spring relocation kit. I checked the sticky but it was never updated with this info.
Thanks!
1. Is it mandatory to remove axles and drain the diff.
2. Does it require a MIG or will a 90 amp wire welder work?
3. The original pinion angle was with 14" tires and they are now 15" and 26" tall. Do I need to place the new ones at a different angle?
Thanks!
.Install new perches without welding . Put wheels on solid surface and measure pinion angle to insure PA.I like 4 or 5* down with leaf springs.Put it back in the air and weld. If using stock perches like I did,brace the back of the axle to the per perch.
