fratzog lover
- 2:01 PM
- Apr 10, 2014
- Northeast Alabama
Nick tries to replicate it. Skip to 18:00.
Correct, as he says in the video.Looks like he’s missing an intake. I guess that’ll be another video
That's an excellent 383 street cam. Bet you get decent MPG too.The engine in my Charger is quite similar only .020 over with the .455 cam and HP manifolds. [9.4 : 1]
It's been together for 23 years and has about 35K on it.
We will be driving it to Carlisle in a few weeks.
I can get an honest 17 mpg.That's an excellent 383 street cam. Bet you get decent MPG too.
Right. They started with a factory AVS they figured for 600cfm, then swapped to an 850 Demon. They agreed it would be over-carbed in the real world, but good for their dyno test.I don't recall Hot Rod running a 750 either..
Unfortunately that is an often overlooked cam. A stock engine build with that cam and headers would make 90 of the B body street drivers happy. They just dont know it, cause they need a "bigger" cam.I can get an honest 17 mpg.
Hence why I went with a Solid on my 451, the hydraulics just ran out of steam, To the tune of 35hpA decent sized fast rate hyd cam...... utilizing any kind of “normal-ish” hydraulic lifters....... in a 383 with decent induction....... is going to leave power on the table.
My prediction is the lifters will start giving up before the motor reaches the natural peak(or potential peak) rpm of the induction system.
Decades ago, a stock bottom end, 906 headed 383 with a single plane and 750 holley proved that theory. It was a total pig.A decent sized fast rate hyd cam...... utilizing any kind of “normal-ish” hydraulic lifters....... in a 383 with decent induction....... is going to leave power on the table.
There was a certain amount of sarcasm to my statement as he tends to make a lot of incomplete or unfinished videos. My guess is to keep piling additional content on YouTube as it probably pays much better than the shop....Correct, as he says in the video.
Not really.. but probably with a76mm bolted on it.383 are torque monsters![]()
