Removing center AC vent
Not in a non rally dash. I had to remove the dash pad to get to the screws for the metal bezel in my 69 Coronet R/T.
If I am remembering correctly, in a 69 Coronet 500 you should be able to remove the cast trim piece. This will allow access to the attachment screws for removal. If this is not the case you should be able to get to it from radio removal or glove box liner removal. There are 3 screws holding it to frame. Two on top and one on bottom.
I have the radio, ash tray and glove box removed. Just not seeing any attachment screws.
I need to look again.
You should find the screws in the bottom lower corners and top center.
The a/c vent installs from inside of dash frame. The screws go through plastic vent holes and thread/screw into steel dash frame. You should be able to remove from inside of dash frame. Did you disconnect the ductwork and remove? This should allow you to see the screws on inside.
