moparsteve636
Try a 50/50 mixture of trans fluid and Acetone it works better than most penetrating oils! P/B Blaster is next to it!
If the engine is really stuck, this is a quick way to get them out. We used a n arc welder, turned up to where it would melt aluminum. Melt two cuts down the sides of the piston. That will collapse the piston and practically fall out.............................MOBeen there, done that. Take a sharp air chisel and bust up the piston. It's not that hard. Just be careful. Makes quick work of it.
Doug
