Removing the starter to fix a leaky freeze plug …
Satellite383
New Member
9:05 PM
Edinboro, PA
Hi all, we’re trying to remove our starter so we can replace the freeze plug behind it. We got the 2 securing bolts off and now the thing won’t budge. Do we even need to remove the starter? I’ve heard how tough freeze plugs can be to get in/out so I figured having the extra space would be helpful. At this point, I’m not so sure :,)
Not sure if I mentioned this in my welcome post, but we are working on our car in the parking lot of our apartment complex (don’t tell our landlord LOL) so although we have a jack and 4 stands, we are limited with what we can do out right for the time being. Any advice/tips are much appreciated!!
Be sure you've got the starter bolts and not a starter bolt and bellhousing bolt...
Provided everything is unbolted you should be able to wiggle it roughly or gently thump it with a block of wood...
Be ready for it to fall the second it's free...
Should be one bolt and one nut.
Should I say because people mess that up frequently
Like Don said, it should be a bolt and a stud if it's still original. And that's a big if.
If you 're sure you have the correct fasteners off, then a few taps with a mallet should free it up, but really, if it is indeed two bolts and you have them both out, the damn thing should just about fall out.
Is that a bolt on top and a stud on the bottom?
