SOLD restored / converted AM / FM / MP3 1968-1970 B body radio
resq302
7:56 PM
northern nj
Feedback: +4 / =1 / -0
Up for sale is a newly rebuilt / restored radio that was an original AM radio removed from our 69 GTX convertible. *We had the radio sent out to Retro Radio to have the AM/FM conversion done with the addition of the MP3 port. *After we got it back from being redone, we realized that the buttons were incorrect for our application as it has chrome push buttons while our car needed the black push buttons. *Radio works perfectly. *Here is a list of the stuff that was done during the conversion:
More power, more features than ever before!
These conversions are made to fit inside the original radio, so they look and feel correct when installed in the dash. We use your face, case, and tuner assembly. When you get the radio back, it will look right, fit right and even feel right. And if it is Retro, it IS right!
Information about the Conversion:
-Original electronics are replaced with a new high power digital stereo receiver designed to work with the original mechanical tuner and controls
-Any analog radio, any year, any model, 6 or 12 volt can be converted
-All original functions are fully operational, including Wonderbar, Town & Country, or other signal seeking tuners; crystal controlled tuning eliminates drift
-Switching between AM and FM bands done by turning the radio off and then back on again when the radio did not originally have an AM/FM switch
-Balance and fader controls are easily adjusted using a unique option that allows the tone control to be used for multiple functions on radios that did not * * * * originally have a balance or fader control
-Pushbuttons can be set for AM or FM stations using the same method that was used originally
-4 BTL amplifiers are capable of delivering 45 watts RMS each - that’s 180 watts RMS maximum output power! (14.4 Volts, 4 ohm load, 1 kHz).
-Radios can be configured for 1, 2, 3, or 4 speakers if powered from a 12 volt system.
-Can be programmed for North American or European channel spacing
-Can be configured to use the original (100 ohm) faders if available
-Original case is bead blasted and/or painted when necessary
-Face, dial, buttons are polished and cleaned
Asking $495 for the radio plus shipping. *Reasonable offers will be considered. *Please contact me via PM with any questions.
How many speakers was this set up for?
Wiring for 4 speakers now. Two gray, two white, two green, and two purple.
for a GTX the face should say "Solid State by Plymouth ."
Chrysler Solid State would be for Dodges and of course, Chryslers.
good luck with the sale!
In 69 they all said Chrysler Solid State. 69 they had the individual brands.
I'm not sure if I clearly understand what you mean? Seems like you are saying two different things.
Sorry, I meant to say 68 had individual brands on the radio. I'll correct the post.
