Right Stuff disc brake kit
dartforforty
Deceased, But not forgotton
7:57 AM
south jersey
Any one use Right Stuff disc brake kits on their early b body cars?
Looking for input...Good/Bad
Ed
Did full kit on 68’ Coronet. Fronts, outstanding and no issues. Rears; most disc conversions use a mechanical lever on the inside pad instead of the small drum brakes inside the disk hub. It has been a real pain in the ***. Adjust tight enough that you have an e brake, and the pads groan when warmed up due to expansion. Back off for no groan, the e brake is useless. Go Dr Diff with the internal drum e brake set up. The external mechanical e brake is turning out to be a poor design.
Get the biggest badest front discs you can afford and leave the rear drums.
My 64 Sport Fury is a factory big block with power drum brakes. Looking to up grade front only to disc.
Should have mentioned this before
Ed
