SOLD ring and pinion posi unit 8 3/4
prov177
8:48 PM
ft laud florida
Feedback: 1 / 0 / 0
this sure trac posi unit was removed from a big block 69 charger with 8 3/4 rear end , it is in good working order , 3:23 gearing , axle spline count-30 , pinion splines-10 , $450.00 with gears , $350 without , plus shipping , yoke available for $45.00 if you need it , axles also available $150 for pair , some other rear end parts available let me know your needs and i will list them
IMG_7726.JPG IMG_7721.JPG IMG_7722.JPG IMG_7723.JPG IMG_7719.JPG IMG_7724.JPG
Do you have the clamp that hold the e-brake to the third member where it goes over the top. Must be in good condition.
i have a set of drum brakes off a 69 charger which still have the e brake cables on them and there are 2 metal clamps wrapped around 1 of the cables , you can see them in the picture , is that what you need?
