pwDave
got the new shafts installed after the snafu with the broken shaft. I had the intake off of the car to open the valley to insure that there was no damage elsewhere,(wasn't any) when I pulled the intake off it tore the grey gaskets all to shtt, couldn't use them again so I went to our local gasket store and had them cut me four .063 teflon gaskets for the intake. had my friend at the fab shop burn me a set of hold downs for the sides of the flimsy pan for the eddy victors. hopfully that will end the oil seep along the edge of the intake pan. when I started it the engine showed no signs of a vaccum leak and I will keep a close eye on it. the four gaskets were 80.00 bux including the set-up for the water table, they are flawless, if they work they will save a ton of money on gaskets, these should be reusable a bunch of times. I will post up about how they work out later. Dave.
