Turn the crank once and it will be at #1. Turn the crank 1 more time and it will be back at 6.
To elaborate:Runs better with new carburetor. Added fuel pressure gauge set at 6psi so fuel delivery is good. I know its its more than likely a timing issue but just can't figure it out. I could be wrong but the rotor looks to be pointing at the #6 cylinder also with #1 at TDC. Not sure what is going on with that.
Dumb question but shouldn't it be pointed at number one on compression stroke rather than exhaust stroke?Turn the crank once and it will be at #1. Turn the crank 1 more time and it will be back at 6.
I gathered from your comments that it runs good. Therefore, the rotor must be positioned properly. No more positioning questions required.Dumb question but shouldn't it be pointed at number one on compression stroke rather than exhaust stroke?
Pull the distributor out and rotate shaft 180 degrees. You might have to rewire your cap as well.Runs better with new carburetor. Added fuel pressure gauge set at 6psi so fuel delivery is good. I know its its more than likely a timing issue but just can't figure it out. I could be wrong but the rotor looks to be pointing at the #6 cylinder also with #1 at TDC. Not sure what is going on with that.
Does it really matter how the gear is installed? Does everything just need to be phased?You beat me to it. I did this for a friend last fall. He bought a '65 Coronet with a 440, It ran, but did not seem to have any power. We found #1 TDC by bumping the engine over on the starter, with thumb over #1 spark plug hole. The distributor/oil pump drive gear was out by one tooth. We also discovered that the TDC mark on the balancer was not right either. We painted a new mark on the balancer, until my friend could get it changed. We put it all back together, and took his car for a drive. Quite a change in performance!
It doesn’t matter. You can make #1 be wherever you want and as long as the firing order is correct from there it will be fine.Does it really matter how the gear is installed? Does everything just need to be phased?
Kinda' depends on the person doing the work and their knowledge I suspect.Does it really matter how the gear is installed?
Seems you're off a bit............Timing mark on the harmonic balancer is at 9 o'clock with the #1 'cylinder at TDC.
If that's true then the balancer has slipped.Kinda' depends on the person doing the work and their knowledge I suspect.
What does the FSM say?
How did you verify the piston is actually @ TDC?
Im definitely a shade tree mechanic..I find tdc with paper or finger pushing out of the cylinder. Even if im a hair off that balancer shouldn't be pointing directly at 9.Kinda' depends on the person doing the work and their knowledge I suspect.
Check your balancer to see if the outside ring has slipped.Im definitely a shade tree mechanic..I find tdc with paper or finger pushing out of the cylinder. Even if im a hair off that balancer shouldn't be pointing directly at 9.
Again if the balancer is not at 0 degrees at TDC then the balancer is likely slipped so you need to put a timing tape on it at TDC and hope it doesn't slip more.Im definitely a shade tree mechanic..I find tdc with paper or finger pushing out of the cylinder. Even if im a hair off that balancer shouldn't be pointing directly at 9.
