RPMs run high then Stalls
Ms.Sully
11:04 AM
Troy, NY
Good Morning, afternoon, evening...
I have a 71 RR with an automatic 383. I bought the car in Feb and she has just been sitting in my driveway because have been working on tuning her up (new choke, plugs, wires, starter). The most recent issue that I could use some suggestions on is that when I start her up the RPMs race up to 3500 and then stalls out, never leaving park. This happens regardless of whether or not the choke is open, closed or somewhere in the middle.
I gladly accept any recommendations on what to check or do, but please know I am learning most of this on my own through videos and the occasional helping hand from family (when they are available) and local automotive shops. If there are videos of what I need to do or check feel free to send them along. Thank you!
Make sure the throttle plates are closed all the way.
In order of possible causes:
- 1 Throttle cable stuck or misadjusted? (take it off the side of the carb and see if the shaft returns closed all the way and compare)
- 2 Severe vacuum leak Power brake hose vacuum line or booster?
- 3 Incorrect or stuck fast idle cam on the side? (But 3,500 is really high not good at all) this cam shoud follow the choke position
