Mopar-Charger
Pretty much the tittle, what will happen is if my battery drains, my headlights won't turn on.
I have a 1973 charger so if you guys are familiar with the instrument cluster, there's the little red dot that lets you know when you headlights are on.
In a perfect situation, the red light only lights up when the head lights are on (low red - low beams, Bright red - High beams)
When I pull the nob out to turn my headlights on, the red light, lights up bright with just my running lights. THen when I pull it all the way out, no head lights turn on, and the red light stays the same.
I've had this problem before, it would go away just by driving the car? (about 30-60 minutes running). I figured it was the battery, I charged it to 100% and it still has the same problem.
Any suggestions, Would be much appreciated. Thank you!
