WTB Scrap 4-1/2” Bolt Circle Pattern Axle
Bob Nossal
Dodgefor72
10:48 PM
Milford, MI
Feedback: 5 / 0 / 0
Does anyone have a scrap 4-1/2” pattern axle shaft? I only need the hub assembly with the studs. Need it as a pattern for some repair work.
If you can find someone replacing front wheel bearings on a Jeep Cherokee XJ, they have the right 5 on 4-1/2 bolt pattern. (I cut the hubs out of my old ones and welded them onto my trailers for spare tire mounts.)
Thank you.
I have a rear axle from an 8 3/4 that I can cut.......
Thanks for offering. How much if shipped to 48381? My original rear brake drums are damaged around the stud openings. I plan to heat the drums around the stud holes and use the scrap hub to flatten the surfaces immediately around the holes.
PM sent
