- 10:02 AM
- Sep 3, 2020
- Cottage hills Illinois
Do you have to do both sides with the adjuster ?
Not to bust on you but leaving out you have green bearings makes the answers more difficult. Since you have side play guess you don't need to remove thrust button in sure-grip assuming you have one.Yes sir I do have a manual. My problem is I ordered Dr. Diff axles with green bearings already installed didn't come with adjuster on it . Checked the end play and it .010 to .012. Wasn't aware of the adjuster until I was watching you tube
There is no need to adjust the endplay with green bearings, but you do have to remove the thrust button from the center section on most axles using green bearings.Yes sir I do have a manual. My problem is I ordered Dr. Diff axles with green bearings already installed didn't come with adjuster on it . Checked the end play and it .010 to .012. Wasn't aware of the adjuster until I was watching you tube
With green bearings you don't use the adjusters. Just a plate to hold the axles in the housing. Green bearings are ball bearings, stock are tapered bearings, tapered bearings require preload to work correctly, the adjuster is to provide preload, just like when you tighten the nut on a front wheel bearing which are also tapered bearings.Yes sir I do have a manual. My problem is I ordered Dr. Diff axles with green bearings already installed didn't come with adjuster on it . Checked the end play and it .010 to .012. Wasn't aware of the adjuster until I was watching you tube
Cass says: No need to remove the thrust block/buttons with the Doctor Diff green bearings and or axles. KimTher
I due have one but I've never seen bottoms in that third member. Even when I had it gone throughNot to bust on you but leaving out you have green bearings makes the answers more difficult. Since you have side play guess you don't need to remove thrust button in sure-grip assuming you have one.
