Shock help
old guys rule
5:38 AM
Jacksonville, FL
Have a set of 70/30 shocks I'd like to use but are 1/2" short for app.. Any way to adapt them too protect the suspension?
with pin type tops there are extenders
or just use them for up limiters, better than bottoming out
Summit and jegs both list shock extenders, jegs has the better selection. From $20/pr to $20+ each. You will need to know the thread size.
When i was working i just would have made some, but retired now, no more machine shop to play in, darn it!
If you need the 20 plus bucks each ones, correct new shocks become more viable.
Yeah, just something lying around the garage I want to try out before spending $. Thanks, Dave
so they top out
you have rubber bumpers? (on the suspension drop)
you could shim them'or just let them top out
as I said too long is what hurts things when you hit big bump
