SOLD Small Block 318 340 360 Distributor Electronic
Roadrunner40
6:33 PM
Eastern Ohio
Feedback: 10 / 1 / 0
I am rebuilding factory distributors and have several cores available and ready to rebuild. This is a small block LA with all factory original parts, I took this down to just housing, walnut blasted housing then every thing is cleaned and checked. Only USA made parts go into this not like the cheap overseas ones mass produced today. Good factory vacuum advance this one has 11 on the arm. Factory original pickup tested, I drill steel collars out in place of plastic ones that break and the shim it for proper end play.
Ready to drop in and run comes with o ring installed and base gasket. I have plenty of cores to rebuild let me know what you need.
$150 Shipped Read Less
Located in Eastern Ohio
2502666D-A247-498E-A7F4-D20F3DA62F96.jpeg 485A18A6-7D42-4EAD-9E0E-B0C9178204C7.jpeg E312E8F3-D8E3-487B-8FB9-0DCCA466F7D3.jpeg 8B650DA0-6B7D-45BC-802B-03ED3B7ADC72.jpeg E68781E9-D97D-4958-96EB-5E6AD4258033.jpeg A029B051-240B-44B6-AD79-5D05065A1EAD.jpeg B28B23A1-8544-4E56-9088-3E409C1E6C2A.jpeg 984208E4-2F54-4E54-A2B3-CC78D74681FD.jpeg CBDDF0FC-E5E9-4C8D-8B00-FA75340BF73B.jpeg
View attachment 712288 View attachment 712289 View attachment 712290 View attachment 712292 View attachment 712293 View attachment 712294 View attachment 712295 View attachment 712296 View attachment 712297
Did you change your mind or what happened?
