Small block 4 speed transmission install question
dodge1972
6:20 AM
Aurora, CO
friend installed a A518/A500 four speed automatic transmission into a 72 dodge charge 340 with a console shifter. He used a blank core to model the installation. Required grinding some material from the case and hammed the tunnel to make additional room for the install. I recall one of the MOPAR magazines had a article on the typical, but I don't recall the issue.
The hump or transmission tunnel on the 75 and later b-bodies a believe is larger, thus my question is has anyone installed a four speed A518 or newer version into the later b-bodies? If your have pleases share some details thanks
The hump is identical. All 71-79 B bodies and 79-81 R bodies and 70-74 E bodies use the same floor, other than some minor differences and humps under the seats for catalytic converter clearance on the 75 and newer cars.
