court9155
For those curious (as I have always been) I had read the stories about how far down in the hole from deck some smogger 440 pistons are. Here is some picture proof. Good news piston and bore look so nice, bad news is piston is .131 in the hole. WOWSA. I have NEVER torn apart ANY engine other than a 3 cylinder GEO METRO that had the pistons this far in the hole. Too bad Im not gonna put a turbo on it. Could be neat with a balance job and some good rod bolts and boost...I digress...
This was a beautiful running 1978 440 with 48,000 miles on it out of a motor home. This is NOT a 440-3 engine. It is just a standard TRUCK 1978 440. I tore it apart out of curiousity and to install a non steel shim headgasket and ARP head bolts along with some decent valve springs (to support a VERY mild camshaft) I am also curoius about the exhaust valve rotator and what will have to be done to put decent springs and retainers on the exhaust side. The seats and guides look beautiful. This is a tapered spark plug (autolite 24s) cylinder head..... I will be adding a small shot (100-125) of nitrous. I am also going to re ring and bearing it and put the new timing set and oil pump I have on hand in it. I have heard the steel shim headgaskets dont hold up well to nitrous, but I am sure the stock piston would **** the bed first. Guess Ill find out.
This is a very budget build.
The motor was purchased for $400
This is a "for the time being" motor until I can build a nice stroked big block and to see how it will live with small nitrous.
Oh yea and I have a 5 year old son to do burnouts for too!!!
To be continued:
To be continued:
