1972 Charger. No brake or rear turn signals. Please advise.
Original wiring harness, thoroughly cleaned. 6 peg plug by driver’s seat cleaned 2x.
Ground to rear was an issue; after running independent ground to rear the running lights worked. Replaced flasher and also turn fuse… functioned, although left side was dim with a very slow flash rate. Turn switch squishy on left activations. Tail light assemblies are new. Steering wheel has never been removed as far as I know ( since 1982).
Pulled the hazard 4 way switch and I heard the fuse blow and smoke rolled out of the steering column by the turn signal lever! Thereafter , turns will not function also, blown fuse. HELP!
We’re pulling the steering wheel asap. Have puller and Chrysler tool to depress turn cut off ring to access snap ring.
Questions: what is the most likely cause? Hazard switch?
Here’s our plan. Please assist us with your experience and expertise.
Pre- purchase-
- hazard switch
- turn signal switch
- dimmer switch ( turn power flows through there?)
- brake switch
Am I on the right track? We’d appreciate everyone’s tech input on this matter.
Great to be part of for B bodies only. Thank you for your help!
Pre- purchase-
- hazard switch
- brake switch
