Doorkicker
I have a similar setup and was faced with an oddity, which may or may not apply, but worth sharing for giggles. In short, the return fuel line created back pressure in the tank after prime, which would cause the pump to shutoff. I had this weird issue and once I relieved the gas tank pressure (i.e., opened the fuel cap), everything went good. I've since solved the back pressure issue.
What would be really helpful is if you would share your GCF file and, if possible, send over the datalog file... the DLZ for the last time you tried. It'll be small, but may show something. Just turn on datalogging by RMP and set to 0... if you haven't already. That way we can see cranking data too.
I may have missed it, but what fuel pump are you running?
I'm assuming you've confirmed pwr and ground at the pump and the Sniper is connected directly to the batt.
OK... one more, just our of curiosity, are you showing less than 11volts during cranking or after the initial start?
