- 4:19 PM
- Mar 28, 2014
- South Louisiana
Thank you to my friends who reached out by PM, I appreciate it more than I can express. Selling this car I thought I'd never sell is a marker for an even bigger change in my life, relationship wise.
PM replies or requests for additional information ONLY please via PM.
Asking $43k
I have had my Lemon Twist 70 Roadrunner for 9 years, and have worked to improve it since I got it.
Unfortunately circumstances are such that I am being forced to sell it.
Also unfortunately the 71 stock bore 440 block w/6bbl intake and by the offset of the harmonic balancer, 6bbl rotating assembly unexpectedly threw a rod in early October.
The description, additions, upgrades, and changes I've made are as follows:
1970 V-Code Roadrunner. 71 440, "6 pack" crank and rods, 292°/.509 Purple Stripe cam, CompCams flat tappet hyd. lifters, springs, 10° locks and retainers. 1 7/8" ceramic coated TTi headers w/Doug's 3"electronic cutouts, 4.10 Dana 60, Strange diff cover, Passon Performance a855 5 speed, Viking B-202 Double adjustable front, B517HF XS Triple adjustable rear shocks, Wraptor serpentine belt and accessory system, Vintage Air A/C, Borgeson Power Steering, Hydramax T.O. bearing conversion, HitMaster launch control, McLeod RXT dual disc clutch, Calvert split mono leaf springs and sliders, Assassin traction bars, Dakota Digital gauges, Strange Engineering chromoly driveshaft and yokes, 1350 U-Joints, Wilwood 4 wheel 6 piston caliper manual disc brakes, Line lock, Cold Case radiator, dual 11" SPAL electric fans w/Dakota Digital controller,
Mancini Racing driveshaft loop, US Car Tools subframe connectors, front and rear torque boxes. QA1 K-member and front suspension w/SPC UCAs. FBO ignition system, aluminum 6bbl intake and Promax modded Holley carbs, Promax upper and lower stainless braided fuel lines, Carter M6903 mech fuel pump, Innovate Motorsports dual wideband O2 system, Blue Thunder console, Scat Procar bucket seats.
Lemon Twist/Black
The picture directly above this, w/the shark mouth, was taken the day before it threw a rod.
Asking $43k
Lemon Twist/Black
