Solid Motor Mounts
61fuel
2:06 AM
maryland
My son has 69 RR 440 built, has a lot of engine shake, tourqe strap attached to engine still has shake.
Banging headers(hookers) on the frame, wants to mount solid motor mounts,
Good or Bad?
Get the poly loc mounts from Shumacher creative services, engine-swaps.com. This should help alot.
Are you sure a motor mount is not broken? I ordered a set of Schmacher Poly-Loc motor and trans mounts because I had a random motor jump. When I removed the old ones I found my drivers side was broken. After installing the Schmachers my engine movement is totally gone, but I do have some different rattles in the cock pit now when it is warming up at idle. My cam has a noticable thump to it and this is what I attribute the rattling to.
Sounds like a broken mount. Get the Schmacher Poly mounts and hook up the torq strap and be done with it. I broke two sets of rubber mounts before I went with Schmacher's. I ran them for 9 yrs before I swapped over to elephant ears and they looked new when I took them out.
