Source or part# for the axle flange gaskets
wannadrag
10:11 AM
Waupaca WI
Anyone have a part# or a source where i cam get them?I'm after the inner and outer brake backing plate gaskets for a 8.75" rear.Stopped at Advance Auto parts but they show nothing.
Don't know where there might be a source but maybe the part numbers from some old ones will help?
Gaskets, Seals
Position Chrysler National C/R Fel-Pro
Axle inner seal 4796698 8695S 15460 ---
Axle outer seal 2404216 8704S 19000 ---
Axle flange, foam 2070933 see flange kit see flange kit 55032
Axle flange, shim 2881314 see flange kit see flange kit ---
Carrier gasket 1673367 --- --- RDS 65833
Pinion seal, 1-7/8 2931862 5126 18708 ---
Pinion seal, 1-3/4 2931862 7216 18912 ---
Pinion seal, 1-3/8 2931862 8515N 18708 ---
Yoke repair sleeve --- 99187 99187 ---
Well, that didn't paste too well but the first set of numbers is Chrysler, 2nd is National, etc....
I've been told the flange kit (with and without adjuster) has been discontinued for 10 yrs now.
I checked the Advance Auto Parts site out and the Felpro #13800 and #55032 are good numbers.Out of stock but will make a run tomorrow to see if they can get them.
i got the 2 59/64 fel-pro 55032 from oreilly this week. had to come from the warehouse.this is the metal one against the tube flange.
Yep and busy as ever.New management a few years back got the place going again.
I checked the Advance Auto Parts site out and the Felpro #13800 and #55032 are good numbers.Out of stock but will make a run tomorrow to see if they can get them.[/QUOTE
Are both numbers required?
Yes you need both numbers,one is for the tin one and the other for the foam one.Foam on the front side and tin on the backside.
The foam gasket from Mopar is 2070933 and the NAPA number is J27962. I'll have to look in ny stash to see if I can find the partnumber for the steel gasket although I have reused the steel one before.
Read the complete post,i have the felpro numbers and they are good,dont need any other numbers.I ordered the gaskets and have them both,the steel and foam.
