Spare tires in bone yard
cj's mopar
7:16 PM
joliet
Hey does anybody know what modern vehicles could be sourced for good space saver spare tire for b body cars?
Modern Ford Mustangs have a 5 on 4.5" bolt pattern. Toyota 5-lug pattern is the same too.
Unfortunately, a flat tire means a tow truck for me. :(
I use the space saver spare from a late 2000's crown victoria I sourced from a junkyard for $10, use it on a 70 roadrunner. Fits perfectly.
If your running a sure grip you should try to find a spare with the diameter as close as possible to your rear tires... Width don't matter but diameter does..
Never thought of that back in the day when I ruined a limited slip in a 1980 AMC. Two hour drive from home and had a flat. Replaced the flat with the space saver and headed home. Should have known better. I don't remember seeing any factory instructions on not to do this on a limited slip rear. Lesson learned :rolleyes:
