speedometer pinion gear help
kelly
6:02 PM
nevada
Someone must know where I can get a 20 tooth gear for my 62 pushbutton trans......
Thanks for the information....
Thanks for the help. They had one. Nothing is cheep for my car that's for sure..
i've seen 21's have a $120+ asking price. i've only seen one 20 and i snagged it!
what rear end and size tires are you using it with?
i ended up using a ratio reducer and bouncing around between a 17 tooth and a 18 tooth with a 3.23 rear. i've used the 20 tooth with a 3.55 rear and a .9 reducer.
Where are you getting the ratio reducer from? Need one for a car I worked on. Went from 2:94 to a 3:73 rear.
I ordered and paid for a .80 reducer about a month ago, it has not shown up yet. I was told that would be a couple of weeks for the gears to come in and it would be made then. Sent an email for information and it took 6 months before I recieved a response.
