wagonman
- 12:27 AM
- Aug 1, 2015
- Deming New Mexico
Just wanted to verify the specs as far as piston deck height. Have heard 0.001 to 0.002 end to end.
Verify it as to what? If you’re decking one, you’d want it located off the main bore and hold .0002”. If you’re checking an assembled short block with a deck bridge, between tolerance stack up and piston rock, you’d be lucky to see it as low as .002 from end to end.Just wanted to verify the specs as far as piston deck height. Have heard 0.001 to 0.002 end to end.
