Standard Dash Install?
dodge68charger
11:59 PM
Washington
Just Wondering How The Center Panel Where All The Switches Are Installs On A Standard Dash For a 69 B-Body..
it Looks Like It Pushes In From The Front But Would Scratch The Lower Dash Pad It Seems Like
Thanks
It does push in from the front - CAREFULLY !! Leave the pad nuts a little loose so it has some movement. Start the switch panel in bottom first and sort of rotate it in.
Like Stanton said, but especially true if the pad has been dyed. Mine's dyed black from the original saddle tan and every time I remove and replace the switch panel I have to touch up the corners.
