gto64gto
I have a 65 Satellite with a 72 auto trans. It carries a 3 pin NSS and back up light switch. My back up lights work each time I'm in reverse but the NSS hasn't ever worked. I looked at a wiring diagram that shows a brown wire goes from the trans to the NSS. I didn't have one so I made one. My question is this. Does the NSS wire go to the same screw terminal that the starter solenoid goes to ? I know the battery cable goes to large threaded BAT stud, a ground to the G spade, and the ignition wire to the I spade. Thanks in advance
