Hi, I need some help figuring out which starter relay that I need,(1 blade or 2)where it mounts at on the inner fender and which wires connect to it. Pictures and info is needed and greatly appreciated.
Propwash posted this caption a while back.
Wire terminal "G" is the auto transmission neutral safety switch,provides the relay coil ground. The "I" terminal is 12v feed from ignition switch,"B" is battery and "S" is to the starter solenoid.
