joemish
The Bendix is hanging up used to whack it with a hammer and fix it Loosen then remount the starter with the proper torque settings and you should have no problemsWent to start my 68 Satellite and now the starter is endlessly cranking - even with the key removed. I had to disconnect the battery to get it to stop.
I've replaced the ignition switch, the lock cylinder, the starter relay... where else do I need to look to figure out what the heck is going on?
Thank you!
