gliderider-06
- 2:38 AM
- Jul 11, 2011
- Delaware, Sussex County
Here is a question for you steering box guru's. I'm rebuilding the suspension on my 71 Charger and am having a time finding a pitman arm. I can get one that has a larger shaft opening, which I guess is for a 73 and newer. Will a P/S box from 73 and newer fit on a 71 with the addition of the pitman arm for it? I can get them from Advance for less than the cost of a cheap pitman arm for the 71. If it will fit, do I need to change the steering shaft coupler as well or will it bolt up just fine?
Thanks!
Thanks!
