Steering column doesn't point straight
68 Sport Satellite
2:48 AM
San Jose, CA
Have had my '68 Plymouth Sport Satellite since 2010 and it has gone through a top to bottom restoration. Only bolt-on goodies for modification to improve handling. Has stock steering column and firewall. Something that has always bugged me from day 1, but that no one who has driven my car has been able to explain is that as I sit in the driver's seat, the steering column points the steering wheel at an approximate 10-15 degree angle towards the driver's door. If I drive with my right hand on top of the wheel it feels like my whole body is crooked. The car drives and handles great. I can't find any indication of the steering column itself being crooked - in fact this is the 2nd column I've had in the car as I found one in better shape - it's that the mounting seems off somehow. If I look at the dash where the vinyl covered controls surround where the wiper button and lights are, this section appears to start horizontally straight from the passenger side and then just past the radio and continuing all the way to the driver's door, it dives in a bit closer to the firewall as it nears the driver's door. It almost looks like it's the design of how the dash is, but how can this be? I've driven many other classic cars and have never observed this issue before where the steering wheel doesn't sit straight in front of you, but is instead at an angle. I was told at one time that there is a bit of play in the steering column mounting position and I've put this as far to the one side as possible to try and compensate, but no real change there. Anyone else seen this issue?
If your saying the column itself is angled & NOT the steering wheel not being centered....then the car was likely in an accident in the past. The whole column is only held in place by 3-4 bolts on the metal column support bracket & the plate/gasket at the floor where it goes into the engine compartment...that's it. You probably can at least straighten it a little bit by loosening all those nuts/bolts, straightening the column & tighten them back down. There's no need to remove any of nuts/bolts completely. While you're in there, take a look for something "bent"
You may need to examine your "steering coupler" to ensure that it was centered correctly. If you have the coupler that I do, those teeth in the coupler may be offset just a little.
Is the column straight to the steering box? It could be an accumulated error from factory tolerences. Just throwing that out there.
thanks for all of the responses! To my knowledge, this is not an accident caused issue. The car is straight as an arrow. Have had the car on a frame alignment machine to check at a frame shop as well as stripped down the whole car to bare metal during the paint process. Straight as an arrow. No bondo anywhere either.
have replaced the coupler and that doesn't seem to be the issue.
Thanks PurpleBeeper! Yes, I did this previously and neither I or my ace mopar guru mechanic noticed anything out of the norm. We did just as you recommend with the bolts. Not a significant enough change.
Has anyone else observed this with a car they have that is known to not have been in an accident?
I think I may have to do a detailed comparison to my buddy's '68 and '69 and see if I can detect what is causing this.
As far as the column being square with the dash, my '62 isn't. It favors to the left. Left side of the steering wheel is about an inch closer than the right side to the dash. That's the way they are designed.
Thanks for letting me know - that's how mine looks as well. Does it make your steering wheel also point towards the driver's side or is it straight ahead?
Power steering or manual steering?
How does the K frame look in the area where the steering box mounts?
It's leaning toward the driver's side. I noticed it when installing the steering column. You really don't realize it's that way.
Now this is on my 1962 so I don't really know about the newer models. I guess its like the drive line when you look at it close enough. It's really crooked and off center.
Measure from one side of the steering wheel to the dash. Then measure the other side to the dash. I get about a inch closer on the left side than the right. :steering:
If everything is straight, your alignment shop just needs to center the wheel by adjusting the tie rod end sleeves. Or you can do it your self, but each one has to be moved exactly the same amount in opposite directions. Otherwise your alignment will be off.
Mine is the same. About 1" closer to the dash on the driver's side of the steering wheel. I have a buddy seat mounted over the trans tunnel in the stock position and that also is closer to the driver seat than the passenger seat. Factory tolerances?
Thanks for this insight. I have a really good alignment shop and I'll explore this option with them.
now that I think of it - do you mean center the wheel circumferentially? Because that's not the issue. The wheel is straight and centered, but is closer front to back to the dash on the driver side. Not sure how tie rod adjustment can help that...
Can you post up a couple of pics of what exactly is off? I am struggling to understand what you are describing.
His column is pointing towards the door...
I'd loosen the lower firewall collar and kick it to the left.
I see. 4 bolts on the firewall and 3 up top. Loosen them up, center the column and call it a day. If that doesn't do it, something is bent.
