steering tight
Texas charger 73
9:42 AM
Texas
is it possible to set steering column in to far and cause steering to be a little tight? already backed box of 1/4 turn... fresh rebuilt box, new pump, new lines, new couplers. steering little tight.. alignment is also good
Did you crank the wheel full turn side to side 3-4 times to bleed the box?
Is it a "firm feel" type box or stock?
The sliders in the coupling should be centered in their travel.
Mike
Mike
i was just thinking maube the column is pushed in to far inside car and maybe rubbing and making it tight since i have tried everything else
Sector shaft adjustment might be a smidge too tight.
