Steering Wheel Help
67CoronetR/T
8:24 AM
Detroit
I am curious... would a 66-67 b body wood grain steering wheel fit on a 68 dart steering column? Is the overall wood grain steering wheel design the same thru 70 for A & B body? Thanks!
That should work I believe the wheel will work with a or b body columns
Your 66-67 woodgrain steering wheel will work on your 68 column. It was 70 when they made the steering columns larger diameter to accept the ignition in the column. Your wheel will fit the 70 also but there will be a little more of a gap between the steering wheel and the column.
Dave
