MikeyM
Hi all,
Happy holidays. In chasing down an off idle stumble in our '69 Bee 383 (Holley 600 80457-2), before I was able to get an adjustable timing light, my initial timing looked to be about 12*. I got the stumble about 99% cured with carb adjustments and the car was responding to throttle input very nicely. THEN I got my hands on the digital timing light in order to set up the full advance with no vacuum and all that fun. I was shooting for 34* due to ethanol, safety, etc. and after landing at 32ish, the initial landed on 14*(Seems to be a MP perf adjustable vac adv dizzy). The odd thing is now the stumble is back... a bit; and I did readjust the carb afterwards. When I aim the timing light at the balancer and then increase throttle, the timing mark seems to retard a few degrees then increase. And at speed, say around 200-2500 RPMs, the timing mark is stable. I've adjusted the accel pump to where the pump arm moves right when the throttle is touched and I have #35 squirters. I was about to change jets to the next size up but wanted to post up here first to see if you guys had any ideas on the timing thing. I was thinking timing chain but the balancer mark doesn't seem to jump around at speed. The Holley was on the car when we got it so I'm trying to work with it so we can enjoy it for a while. The original jetting, according to the Holley site, is 66 and it has 65s in it so I was going to go back to 66s to see if that makes it happier. Anyway, any input you all have is most welcome.
Thanks for the read,
Mikey
Mikey
