STREET DUTY SPARK PLUG RECOMMENDATION?
2vette2camaro
7:39 PM
Arkansas
I am looking for spark plug recommendations for getting started with my combo.
451 low deck, 11.2 comp,
trick flow 240 heads
230/240 @50 110 cl
gasoline
msd 6al ignition
primarily street duty.
I am looking for a recommendation to start working with.
I'll be watching. I'm building a 512 w/ Trick Flow 240 heads. Will be for street use. Ruffcut
BKR6E if you like NGK. As long as those heads take the common 14mm thread x 3/4" reach plugs.
#3924 Autolite are what I use in my Indy heads (14mm x 3/4" reach).
I am using NGK-R5671A-7 with my Indy EZ heads. Indy recommended these plugs since my car is a 99% street car that I race once or twice a year. Been using them since 2011 and never a problem. My eng is a 493 (440 with 4.15 crank) and 10.6 comp with good .046 quench. Never any ping at 36 total and runs great. Ron
Same here, R5671A-7 on our 10:1 mild race headed/solid roller 589, no problems yet with 40% street use + 60% race, I've personally never used anything but NGK ever on my junk in the past.
