470 Spark Plug Starting Point
68Dart470
5:20 AM
Belchertown, MA
Looking for a couple recommendations on spark plugs for a mild race build. Just to get break-in and dyno done without issue.
400/470 Stroker
Flat Top Pistons .004 in the hole
0.040" MLS Head Gasket
Performer RPM Heads - Ported
Approx .615" Lift Solid Lifter Cam
Trick Flow Single Plane Intake
Firecore Distributor & Wires
Hooker Fenderwell Headers
MSD Ignition
4-5,000 stall w/727 & 4.30 Gearing
400/470 Stroker
MSD Ignition
ngk 5`s
Depending how the compression plays with the fuel, might go a couple colder
R5671A-7
I did forget to mention compression & fuel.
10.5-1 Compression
1000cfm Holley 4150
Race Fuel (Maybe Mix with 93 If Possible)
Naturally Aspirated
NgkBRK6E is what I would run. Use the same plug in my 10.5:1 strokers.
RPM heads use “C” series plugs.
NGK BCP6ES or BCPR6ES
Looks like the BRK6E is basically the same thing.
NGK 5s. The 'K' has the ISO nose, which I believe projects slightly further out into the chamber. Using these in a 4 heat range & very noticeably improved idle quality.
Thanks Guys. Will try out a set of those BRK6E's. Look pretty reasonably priced as well.
