Stromberg WW3-250 Rebuild kit help
Nasuno
New Member
1:58 PM
Wa
What is the most comprehensive rebuild kit for a Stromberg WW3-250?
My 65 Coronet Poly 318 and I would appreciate the help as we can not find one we like.
Thanks.
ps. It might be a 251 as its the automatic transmission though I doubt it matters as the service manual inclines me to believe they all have the same insides.
I might have the numbers backwards but the specifications for the car state 250 but the auto trans was an optional so I'm assuming that's the 251.
Again not that I think any of this matters, any good WW3 kit will do me well. What do you pros think?
ps2. Autozone says I can send it in to be remanufactured for $200 so I bought one off ebay for that experiment.
Your thoughts on this as well, if any.
Thanks again.
That was on the top of my list.
Thanks for the recommendation.
Any auto parts store that still uses and has the catalogs under the counter should be able to get you the right carb kit you just need to supply them with the carb# off the tag on the carb go to a established been around a long time parts store and not one of the big box stores and you should get the right one you need
