Suddenly No Turn Signal or Brake Lights with working Taillights and Hazards
67satellite
1:27 PM
Illinois
Turn Signals = NO
Brake Lights = NO
Taillights = Yes
Hazards = Yes
All has been working fine since my rebuild several years ago, but just today I have lost my turn signals and brake lights. The fuses are good. There is no clicking from the signal relays. Al bulbs are working for taillights and hazards.
I know all of this wiring passes through the signal switch which was replaced during the rebuild, but the fact that the lights are functioning reliably otherwise, makes me hopeful someone suggest something else before I start digging into it.
Thanks!
witch is about the only place that can effect both at the same time. check for power at your brake light switch just to seperate the rear from the front.
Thanks all. I will start with checking the connector and brake switch. Previous research led me to buy the Shee-Mar brand signal switch, is this still the best option?
Turn signal switch is probably the issue.
Grounds should be fine if the tail lights are working.
