Sun visor replacement
62440
9:38 PM
Chilliwack BC
I bought a set of replacement sun visors for my 62 Plymouth. I tried putting them on the arms and they were super tight. I sprayed silicone down inside and managed to get them on with a crazy amount of effort. The next one l used silicone grease and the same deal. Now they move but it takes 2 hands to do it. I'm thinking they are a "Pile of Crap" Would anyone know if the 3 holes that mount them are a standard size within Mopar ???
Are these reproductions from some company? I had Legendary redo mine, they work perfectly. Should be a spring steel clip inside that holds tension on the rod, mine work easily with just one hand. Also there should be a bracket above the headliner with four holes, one larger one in the center for the pivot and three in a triangular pattern for the screws. The early Bs are all the same pattern as far as I know. Pictures?
I replaced mine too, same problem buit I an finding that over time they are loosening up.....
The three hole patteren isn't standard. Some might interchange but I don't know which ones.
I found a set of used visors from a chrysler and they were identical to my '62 dodge but the three hole plate had a different screw pattern. I pulled those arms out and used my original arms. I know there are different diameter rods also.
Can you compare/measure the inner diameter from you old ones to the new ones?
https://www.forbbodiesonly.com/mopa...p-new-residence.114133/page-30#post-911008250
See, I learned something new today! Every one that I’ve ever seen were identical.
Mine look's like Red63440's. l don't know who made mine, My car was just a rolling shell when l got it, it didnt even have sun visors, l got mine from Joe Suchy. So much Great info on this site. Thanks Guys
